My Cougar failed it's MOT this morning in rather spectacular fashion. Due to the rot/corrosion which has been identified I don't think it is worth repairing.
It's a 2000 X Plate silver C2, with 106k miles on the clock. Is this worth anything as a parts car/spares or repairs? Or am I best off sending it to the scrap man for £200? Some old pictures of the car can be seen in this post here; https://forums.ukcougar.club/thread...l-future-owner?p=451403&viewfull=1#post451403
Repair immediately (major defects):
Offside Front Suspension component mounting prescribed area excessively corroded significantly reducing structural strength floor area (5.3.6 (a) (i))
Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength outer sill (5.3.6 (a) (i))
Nearside Front Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced outer sill (6.1.1 (c) (i))
Rear Exhaust system insecure system joint (6.1.2 (a))
Parking brake efficiency below requirements (1.4.2 (a) (i))
Monitor and repair if necessary (advisories):
Nearside Rear Macpherson strut mounting corroded but not seriously weakened (5.3.3 (b) (i))
Offside Rear Macpherson strut mounting corroded but not seriously weakened (5.3.3 (b) (i))
Nearside Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Offside Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
