Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: TOGUARD Mirror Dash Cam
  1. #1
    Member dandamano's Avatar
    Join Date
    Aug 2011
    Location
    Wolverhampton
    Posts
    4,023
    2,403 Thanks given
    Thanked 2,647 Times
    in 1,927 Posts
    Default TOGUARD Mirror Dash Cam
    Been after a dashcam for a while and came across this Toguard one on ebay
    For the price of 27 couldnt really go wrong
    After having lived with it for a few days this is my review
    Good
    1. Simple to install and use, simply clips onto the existing rear view mirror
    2. Video quality is excellent 1080p on front camera and 720p on the rear
    3. Rear camera is included and records both front and back and sound
    4. The parking sensor is very good any knock or loud sound near the car sets it to record
    5.The files saved to the SD card are seperated and easy to find, it names the files so you can see it at a glance if its the front or rear camera or a parking sensor recording
    The Bad
    1. If you of average height like me to get a perfect view in the front camera you have to angle it at such a way you cant see all in the rear view mirror without ducking a little, but this can be counteracted by using the rear camera to display on the screen or loosing a little side view of the front camera
    2.On the cougar you can see a corner of the standard rear view mirror behind this one(not an issue on the focus)
    All in id recommend this camera to anyone in the market for one
    Ill post a 'how to' of fitting it including how to hard wire it in the coming days
    Ebay link to item
    https://rover.ebay.com/rover/0/0/0?m...2F183137387250
  2. The Following 4 Users Say Thank You to dandamano For This Useful Post:
  3. #2
    Member Everton's Avatar
    Join Date
    Oct 2009
    Location
    Coming Soon....
    Posts
    5,181
    1,815 Thanks given
    Thanked 2,548 Times
    in 1,600 Posts
    Default
    Quote Originally Posted by dandamano View Post
    Good
    The Bad
    Ebay link to item
    Good review, I've got something similar but RAC branded - doesn't have rear camera but does have speed camera warnings. I noticed the same where you have to angle the mirror to get a full front view for the camera which means you have to lean over slightly for a full rear view in the mirror. I wonder if this is due to having been intended for LHD markets with the camera mounted on the left side of the unit? Anyway, have been in the market for a second one for Wildcat so may well invest in one of these
  4. The Following 2 Users Say Thank You to Everton For This Useful Post:
  5. #3
    Join Date
    Aug 2011
    Location
    Wolverhampton
    Posts
    4,023
    2,403 Thanks given
    Thanked 2,647 Times
    in 1,927 Posts
    Default
    Thats a good point about it being designed for the LHD market, I did think when fitting it trying to get a good view of the road on the camera with still being able to see in the rear view it would be so much better with the camera on the other side of the unit, our cars being RHD explains it
  6. #4
    Moderator Relliott6879's Avatar
    Join Date
    Jul 2009
    Location
    Winchester
    Posts
    5,382
    1,801 Thanks given
    Thanked 2,471 Times
    in 1,501 Posts
    Default
    I may well get one of these for Millie the Micra. I'd love one in the Audi, but I'm a little nervous of messing about with that, lest I bugger something up!
    Quote Originally Posted by Pid_16V View Post
    In all fairness though, i do think they should limit any engine size to at least a V6 config
  7. #5
    Pid_16V's Avatar
    Join Date
    Nov 2006
    Location
    Posts
    25,837
    4,843 Thanks given
    Thanked 7,153 Times
    in 5,002 Posts
    Default
    I had a similar thing to this some years back in the Sierra iirc, very good it was too. Back then it was called "Magic Mirror". I have the mondy anti- dazzle mirror in DG atm but am considering replacing it with another one of these but i am looking at the central display ones, @ +5
  8. #6
    Join Date
    Apr 2005
    Location
    warrington
    Posts
    207
    30 Thanks given
    Thanked 19 Times
    in 18 Posts
    Default
    Fitted today for me about an hour at my speed try it out tomorrow on way to work rear camera stuck on rear window didn't realise how much cable hiding there is not hot wired it in to overhead light see how it goes so far so good
  9. #7
    Pid_16V's Avatar
    Join Date
    Nov 2006
    Location
    Posts
    25,837
    4,843 Thanks given
    Thanked 7,153 Times
    in 5,002 Posts
    Default
    I've been using one of these for a few months now and find it very good. Also working on making it a better fit on the oem bracket.
  10. #8
    Join Date
    Apr 2005
    Location
    warrington
    Posts
    207
    30 Thanks given
    Thanked 19 Times
    in 18 Posts
    Default
    Yep tried tested works great even when not plugged in to ciggy lighter records bump I no lol question how many leave it plugged in to ciggy lighter is there a drain on battery thanks oh and happy Easter
  11. #9
    Pid_16V's Avatar
    Join Date
    Nov 2006
    Location
    Posts
    25,837
    4,843 Thanks given
    Thanked 7,153 Times
    in 5,002 Posts
    Default
    I've hardwired mine so no need for the ciggy lighter and wires dangling all over the dash. I have it permanently "ON" monitoring parking but it only draws any kind of current when the am actually switches on. The dashcam auto switches on with the ignition.
  12. #10
    Join Date
    Aug 2011
    Location
    Wolverhampton
    Posts
    4,023
    2,403 Thanks given
    Thanked 2,647 Times
    in 1,927 Posts
    Default
    Ive hardwired mine in too so cant comment for sure but I wouldnt leave it plugged into the ciggy lighter when the engine isnt running as it will constantly be drawing power to charge the interal battery on the dashcam
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
