Hi All,
Been meaning to post this for a while now, so here goes.......
Somewhere in the depths of the backend of our beloved Cougars is something which quite possibly could cause us a lot of aggro, and I mean right up to the full checkout syndrome!!!!
The design engineers in their infinite wisdom, decided to hide the rear brake pipes up above the rear subframe which, to be honest is very difficult, bordering impossible to inspect!!
The two rear brake pipes run down the right hand chassis rail and up along that rail all the way back to the rear subframe, both pipes then go to the centre of the car where they cross from front to rear of the subframe, then back out to their respective wheel arches.
Now the worst bit i came across was the front side of the rear subframe, in the corner of the chassis rail above where the fuel filler enters the tank.
Couple of pics to show.......
In this one you can see the brake pipe crossing the chassis rail in the top left of the pic, it then follows the chassis forward and centre before crossing the lightweight box section before returning to the chassis rail and going forwards
This one shows the right hand chassis rail by the fuel tank, note the connector unions on the right........
.....which are on the left here........both pipes in this corner were not only just fragile, but with a minor......and i emphasise MINOR movement, one of the pipes actually cracked in two, with instant fluid loss!!!
Check your pipes people.......one day you may need them!!!
I'm hoping that this is waved under the noses of all newbies and current club mechs........this is not something to be ignored!!
If mods can sticky or make public then please feel free to do so
